2002 non-tii coil over struts modified by Ireland....
320i vented rotors, volvo calipers. OK, I mounted the calipers with the nipple on top...that certainly helped with bleeding.
Now I am having a problem with the calipers scraping the inside of the rotor. Both sides are scraping equally. APparently I am missing a spacer or I have something wrong.
Is there supposed to be a spacer used here? It didn't seem safe to put washers in between the caliper and the strut brake bracket.
What should I do?
Thank you!!!
Scottie Sharpe
68 2002 Mikunis Ireland coilover e12/e21 brakes
88 Dinan M5 stage 4 M88/3 conv, Miller MAF, B&B, 3-pc Fikses 17x9fr, 17x10rr, Racelogic traction and launch
Webmaster for http://bmwturboperformance.com
Do you www.bmwWikiWiki.com ??
What should I do?
Thank you!!!
It's ok to put spacers, you need them. About 2 mm spacers will center the caliper with the disc.
Tommy
centered the calipers over the rotor. They are a bit of a PITA to squeeze in there but they certainly don't weaken the clamping force from the bolts.
John N
