Check the 3 wire connector on the back of the alternator. My car had the same symptoms and it turned out the connector had vibrated loose. The little keeper spring was missing. If all the connectors are in place, then it is most likely the voltage regulator giving up.
Steve J
& too many bikes
the alternator frame to the engine block...it can look good but the terminal connections can be vibrated loose or broken...
check the brushes. They could be on the hairy edge of worn out, with the extra vibration making them lose contact with the armature.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
