I currently vent the crankcase into my air filter. I was thinking of changing it to one of the little filters that attaches to the valve cover. Any thoughts? Pros/cons? Is one brand better than the other?
This is an example of what I'm talking about...
http://www.2kracing.com/product_info.php/cPath/26/products_id/1474
1975 - 2002 - Sabine - Jade
2010 Toyota Matrix XR
Remember: RACECAR spelled backwards is RACECAR
---As prescribed in the 2002 Restoration Guide book.
Some may argue that I'm killing baby wombats with this practice, but I don't have any emissions testing or inspections in my state. The filter you talk about won't hurt as long as you cap the hole on your aircleaner.
Ben
--> 1968 2002 <--
Its a fine mist, but mist nonetheless. It will mess things up over time.
And, the filter could plug up and cause pressure.
The filters are nice and shiney.
If you don't like burning the crankcase fumes, you could install a nice shiney catch can.
'76 2002 (Sold)
2002 Subaru WRX Wagon (at least it's a 2002)
Yours appears to be set up neatly and correctly. There is no advantage to dumping your blow-by directly into the atmosphere. Is your setup causing any problem?
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
RUN IT IN TO A CATCH BOTTLE , or
hose to the lower frame rail,
but having the filter just adds oil
vapor fumes to your interior/venting system,
and when the filter becomes blocked - more agro.
The little filter is not a good idea.
'64 R27 250cc #383851 18,000m
I'm having my valve cover powder coated and as I was removing the braided line I stabbed my thumb on one of the ends... This got me thinking... I saw one of the little filters and thought if they work just fine, why not... And, no more blood letting!
I remember getting stabbed by the vacuum hose to the brake booster. The crankcase vent hose can be ordinary rubber; it doesn't need to be braided.
Curt Ingraham
Yes, it doesn't need to be, but it sure does look purdy! The blood simply rinses off, no problem!
I went a little bizarre! My wife complained about the oil stink in the garage everytime I shutdown the engine (tight at only 4k miles too!) So I used a few different ideas together. Catch can plus drag race vent to the exhaust system to scavenge at engine speed. I am assured of .01 extra horsepower @ 7000 rpm!
So valve cover breather to a little oil catch can mounted a bit higher on the firewall. This is to allow any oil to drain back after shut down. From there down through a one way exhaust valve (Moroso or Summit) and then to a nipple welded after the header collector.
So far no problems and no smell.
Yah, I know... "nice engine but look at that dirty washer bottle!"
'74 Inka 02
So valve cover breather to a little oil catch can mounted a bit higher on the firewall. This is to allow any oil to drain back after shut down. From there down to through a one way exhaust valve (Moroso or Summit) and then to a nipple welded after the header collector.
O.K. You win! Somehow I don't think I'll attempt that... I may just go back to my original setup when I get my valve cover back...
Thanks for all the tips/hints guys!
