anyone have suggestions for decreasing noise inside the car? my door seals look pretty new, window seals are pretty decent as well, but i get this loud whistling and air. is this the best its gonna get? anything else i can do?
Do you have an antenna on the A-pillar? Mine whistles really loud, and the antenna doesn't even work with the radio....I just pop in a cd and crank it...problem solved!
Brian
72 inka
chunks of packing foam or even styrofoam peanuts (in plastic bags, of course). Just make sure you don't have any backlight leaks, or the foam will hold water and accelerate floor rust.
Also, peel up your floor carpets and install some household carpet padding underneath (again, make sure no water is leaking in to saturate the padding)
You'd be amazed how much quieter the car will be inside.
Also, remove door pannels and adjust the 1/4light window frame so you get a good tight seal with the door seal. while your in there put something like Dynamat on the inside of the door.
Another great place to put Dynamat is behind the the rear interior side pannels and on the floor under the rear seat.
John
1665778
