Ok.. this is the first time I've had a 02 motor that has a dipstick housing that is attached to the block by a rubber hose with hose clamps.
To me this design is flawed since the housing can be pushed in and out + or - 1 inch, which will change considerably what the oil level will indicate on the dipstick.
Question: what's the correct distance of the dipstick housing to the male part that sticks out from the block?
Parts 4 thru 7 in the diagram.
http://www.realoem.com/bmw/showparts.do?model=2552&mospid=47140&btnr=11_2377&hg=11&fg=30
71 2002
90 E30 M3
99 E39 528i
Dont know the correct length, but there should be a bracket from the intake manifold to the dip stick tube that supports it from vibration (see on tube 1 in pic) and would not allow that much movement. Beaner7102
Drain the oil, put a new filter on, then fill with 4.5 US quarts. Check dipstick, relocate appropriately.
EVERY 02 I've ever owned has been of the "hose" variety. It has it's benefits - especially when fitting big, stoopid carbs.
Paul Wegweiser
