I'm rebuilding my weber 32/26 per cd's prescription. He says Float Level 40mm. Mine are of the plastic variety. how do you measure and where from?
thanks
dave
1972 2002
Verona Red "Happy Face"
VIN 2581641
1999 M Roadster Alpine White, 1999 M Coupe Alpine White
Correct float setting for the plastic float is 35mm from the base w/ the float closest to the base or 51mm from the base when the float is in the farest position from the base.
Go to this for diagrams;
www.piercemanifolds.com/Float_Level_1.htm
thanks...that give me exactly what I need...
after I took off the jets from the old carb I found the following:
PRIMARY
idle 60
main 140
air correction 120
SECONDARY
idle 50
main 140
air correction 160
I'll be replacing with this:
PRIMARY
idle 60
main 140
air correction 145
SECONDARY
idle 55 (may stick a 60 here)
main 170
air correction 175
1972 2002
VIN 2581641
