uxoman Posted March 4, 2006 Share Posted March 4, 2006 Anybody with a picture of the mounting location of a tii fuel pump. I need to mount a tii pump for my M2 project and have only a general idea where it mounts. TIA Quote Link to comment Share on other sites More sharing options...
_z_ Posted March 4, 2006 Share Posted March 4, 2006 check keiths page http://www.my2002tii.com/june_2001.htm Quote Link to comment Share on other sites More sharing options...
_z_ Posted March 4, 2006 Share Posted March 4, 2006 http://www.my2002tii.com/tii-fuel-pump_how-to.htm Quote Link to comment Share on other sites More sharing options...
uxoman Posted March 4, 2006 Author Share Posted March 4, 2006 so there aren't any brackets on the car. I guess I'm looking for the guy's with a non-tii car that are now M2's. Thanks for the effort, though. Quote Link to comment Share on other sites More sharing options...
BLUNT Posted March 4, 2006 Share Posted March 4, 2006 phil, it sounds hokey but a fence post strap is the exact size of an e21 pump. i think a coil clamp is also. i plated mine yellow cad and am going to mount it up by the right halfshaft with a rubber isolater Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 5, 2006 Share Posted March 5, 2006 The electric fuel pump mounts to the right of the differential. There is a mount that is welded to the underside of the body. I have several of these mounts taken from parted out tii cars if you want to make it look original. shermanmartinez@hotmail.com Quote Link to comment Share on other sites More sharing options...
bergie33 Posted May 9 Share Posted May 9 SUPER old post, but I am looking for the same thing...pics of the fuel pump mounting from a tii. The pics on Keith's website are a little low-res and the area is a little rusty, so it is hard to make out the details. Does someone have a good pic of the body brackets, without the fuel pump mounted? Mine are all bent out of shape and I am trying to get them back to the way they should be before painting. Quote Link to comment Share on other sites More sharing options...
NickVyse Posted May 9 Share Posted May 9 here you go, 72 if it makes any difference 1 Quote Link to comment Share on other sites More sharing options...
bergie33 Posted May 9 Share Posted May 9 Perfect, thanks Nick! Quote Link to comment Share on other sites More sharing options...
pehlivanov_tii Posted May 14 Share Posted May 14 Quote Link to comment Share on other sites More sharing options...
jgerock Posted May 14 Share Posted May 14 Alternative to factory tii fuel pump with expansion jar/bracket is the in tank fuel pump/sending unit for e30 318is. I converted my tii to this a long time ago. Quote Link to comment Share on other sites More sharing options...
bergie33 Posted May 14 Share Posted May 14 32 minutes ago, jgerock said: Alternative to factory tii fuel pump with expansion jar/bracket is the in tank fuel pump/sending unit for e30 318is. I converted my tii to this a long time ago. Does that sit right at the bottom of the tank like the original setup? I thought there was some discussion about potential fuel starvation on hard cornering when low on gas? Quote Link to comment Share on other sites More sharing options...
jgerock Posted May 14 Share Posted May 14 1 hour ago, bergie33 said: Does that sit right at the bottom of the tank like the original setup? I thought there was some discussion about potential fuel starvation on hard cornering when low on gas? Mine puts the pickup sock right close to the tank bottom. Never had any issues. I try not to run the tank near empty anyway. Quote Link to comment Share on other sites More sharing options...
