carbs which one to choose
i have a bmw 2002 from 1972 and whant to know if i can fit a twin carb on it and if so which one.
Help!!!!!!!!
YES - but don't 'over carb'
it.
WEBER 32/36 is the bomb,
with a side order of manifold
'64 R27 250cc #383851 18,000m
BUT, the biggetr the carb - Generally - the less smooth you'll be around town. We call that "drivability" issues.
the 32/36 with CDs special prescription applied, is good for stock or only mildly modified set-ups.
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
2 bbl downdraft...bolts onto your late 72 or later 2 bbl manifold with minimum fiddling, gets good gas mileage (better than the 38/38 Weber) and is much smoother running then the OEM Solex 2 bbl.
You can always go with one or two sidedraft Webers or Solexes, but you won't get a lot of extra performance from them with a stock engine. You really need higher compression pistons, a hotter cam etc...
Go for the 32-36 Weber...
And, will it just sit in the same fixture in the firewall as the stock part?
'76 2002 (Sold)
2002 Subaru WRX Wagon (at least it's a 2002)
rod...worked just fine...
also in the manifold pic, the metel pieces between each cylinder runner looks like the metal has been cut out. Why is that? Just for looks?
69 2002 1668997 "Geboren ein Hölle"
Shhhhhh... Another Whispering Bomb!!
