I put on a different radiator and a non off brand tstat i had laying around and bam - no overheating. But I have a coolant leak which appears to be dripping from the exhaust side of the block. While ive been typing, it occured to me that it could be the drain plug on the block. Thank you message board! lol
Patrick Sloan
1975 inka 2002 - 2375719
1991 325iC
2001 325i
Old hoses become hard and brittle and will sometimes crack after being handled. Old hose clamps are also known to strip out if overtightened. If you've not had the problem before and since that's what you've changed recently, that's where I'd look.
Hope this helps.
Yeah its all fresh. I'm thinking its the drain on the block. I'll check later.
Patrick Sloan
1991 325iC
2001 325i
Pat, Glad you solved you problem. Keep the faith. Beaner7102
a rusted out freeze plug. The one that you have to pull the motor out to get to. Or it could be a broken through water passage in your block. Just kidding Pat. Sounds like a plug. LOL
