Are these the right ranges?
Volts: 8-16
Oil Pressure: 0-5 bar
Temp: 50-150 C (assuming this is for oil temp, but not 100% sure.)
If these are correct what are the normal running ranges?
typical driving
voltage 14.2
pressure in bars 0-5 is 0-72.5psi
1 bar =14.5
new engine around 60psi driving
20-28psi idle
temp 50-150 c
122-302 f
driving water temp =192f
oil temp checked in bottom of pan around 134f
these are my findings with 5000 mile rebuilt engine and
vdo vision gauges and senders
enjoy
FO 2573825
1971 2002, 5-OD, Recaro SE, BBK, 90Amp Alt, Turbines, VDO, Hellas, BD belts, LED Tails, 10 Foot DD
peg on a cold(ish) morning, especially if you're running 20w-50 oil. I've seen 120 psi on my well-worn engine when the temp is in the high 20s-low 30s...suggest you get the metric equivalent of a 150psi VDO gauge (probably 0-10 bar)
