Sorry to detract from those sold on the forum, but I found this one locally for only $14.
I just noticed it hangin on the wall at the local import parts store, and saw that it pretty much matched up. I grabbed it and the parts store guy said "You got a VW too?" I said nope, but it looks the same as mine.
It matched up perfectly, and came with gasket, and two allen bolts with the proper threads and lengths. It was a pain removing the old studs, but a tight jam nut got it off.
The brand name is 'Empi' and part number is 31-3011-0.
I also took an hour or two to polish my valve cover for the fun of it, and added a coolant tank.
Pics are all in this folder:
http://www2.hawaii.edu/~kfunk/cover/sub/
It was gettin dark so it doesn't show up very well, tried with and without flash. I basically used 80 grit sandpaper, then 120, then 400, then 00 steel wool with mother's metal polish. If I had a DA air sander with polishing pad, it'd be bright and shiny.
But that was a fun freebie mod for a little bit of elbow grease.
Bring a Welder
do you have a part #
It says it right below the pic, Empi is based in Anaheim and their part number is 31-3011-0 "Billet fuel pump block-off." It was $13.95 here, but prices may be a few bucks lower on mainland.
Bring a Welder
Not quite as fancy as the Empi part, but these are what I've been using:
11 12 1 254 991 fuel pump blanking plate, List $5.10
These have actually dropped in price slightly -- six years ago they listed for $5.70. You should get a Dealer to give you 20% discount off of the list price.
All day long. If anyones looking for me email me and I can purchase some and ship them off.
If more power is better then way too much is just enough.
"Why do it once when you can do it thrice!"
thats pretty nice. i got one for free cuz my dad is an engineer at a shipping yard who makes all the steel parts to build bridges, and they have bunches of left over material so i made a template and one of the fabricaters cut out some quarter inch steel, i drilled the holes, painted it and got a free part.
I thought about the DIY before, and had friends with machine shops, but it was too much hassle. Then you'd have a challenge trying to make it look 'factory' quality. I've just left the dead pump hangin on there for a while. Was gonna order an FAQ one, but thought I'd try this one out first.
Come to think of it, I wonder if a VW fuel pump would work on the M10? Not sure why that'd be good in any way. Maybe they're easy to find or cheaper...
Bring a Welder
Yup VW fuel pumps work
I fabricated one from aluminum. It does the trick!
1975 - 2002 - Sabine - Jade
2010 Toyota Matrix XR
Remember: RACECAR spelled backwards is RACECAR
