the duration of a 292 cam is 292 degrees, but how can you determine lift?
Aashish
1969 BMW 2002--I gotta finish this damn thing
1987 BMW 325is--S52 Monster
1975 Innocenti Mini 1001-- the most cost dense car ever!
1995 318ti
2004 BMW 330i ZHP
2004 Toyota Tacoma (gotta have something reliable!)--can't live without
measure the base circle and then subract from the overall lobe height.
Then multiply by the rocker ratio.
FOR DR SCHRICK CAMS:
Duration............Lift
284.................9.5mm
292..............10.0mm
304...........10.7mm
316........11.1mm
328......12.0mm
336..12.5mm
and for Ray Korman Reground cams:
300.........9.4mm
30......11.1mm
'64 R27 250cc #383851 18,000m
Hi Ashish,
As noted above measure the base circle (preferable with a micrometer) The subtract the base circle diameter from the lobe height (bottom of base circle to tip of lobe. This will give you the camshaft lift. Depending on who's camshaft you are measuring (I will assume schrick) they give the specs for the camshaft lift or valve lift (taking into account rocker ratio).
Here are some specs for Schrick Camshaft lift (m10)
284 - 7.2mm
292 - 7.6mm
304 - 8.2mm
316 - 9.1mm
328 (328/316) - 9.2 / 8.5mm
336 (336/328) - 9.5 / 9.2mm
