what kind of differential does an e36 325i have?
my friend has the car and wanted to know what the differential is.
who knows
its a cast iron housing unit made by BMW. what the hell kind of question is that?
What year?
'92-'93 had limited slip and the '94-'95 had an open diff because they had traction control.
Across the board? I was wondering, as my dad's 325i (93) was always in question. I guess i'll do the burnout test.
Geeze. don't bust his balls.
Dutch, I don't mind all the questions, just be alittle more detailed? are you thinking it might fit an 02?
I'm not sure offhand what the E36 has for a diff but, i believe the pinion/ring gears could be installed into an 02 diff for crazy ratios.
sorry , no i wasnt thinking of transplanting. i am simply asking what is the final drive ratio and if it is a limited slip or not.
Or just jack it up and rotate the wheels.... if its the same direction its a LS diff.
Yes, I believe all the cars had LS until they came out with ASC.
Rumor has it that a very limited number of '94s may have had both. Probably due to the usual overlap in production.
-Justin
  • 3 years later...
can a 97 M3 with asc have lsd as well and if no why not have both if its a M3 or one or the other.
