I've come to the realization that my Weber 32/36 could do with a rebuild. I have no idea what its history is and the engine is running way too rich....
I've seen CD's and others Weber prescription and the recommendation for going to Pierce Manifolds to get the repair kit and gasket set. My carb is a DGAV 33B1. It appears to be an electric choke type (yes, I only receently found out that there were different kinds of chokes!).
Anyway, I understand that the rebuild is straightforward. I will also be getting the following, using the CD prescription:
Float Level 40mm
PRIMARY
idle 60
main 140
air correction 145
SECONDARY
idle 55
main 170
air correction 175
I tried calling Pierce but they are out (Presidents Day?). They have an online ordering system but I thought it would be better to talk to someone on the phone in case I bungled the order.
Anything I'm missing here?
thanks
(technically-challenged hack wanna-be 'O2 mechanic)
1972 2002
Verona Red "Happy Face"
VIN 2581641
1999 M Roadster Alpine White, 1999 M Coupe Alpine White
Get a Weber book, if you want some diagrams, but it's really straightforward. There's a lot of stuff online if you google.
Make sure you get the right kit for the numbers on your carb.
There's jameng.com and carburetion.com also.
'76 2002 (Sold)
2002 Subaru WRX Wagon (at least it's a 2002)
could not get a hold of Pierce so called Top End Performance instead.
Ordered the parts, but they also recommended strongly a 60 idle jet for both primary and secondary, whereas CD recommends 55 for the secondary....so I got both (extra 6 bucks)
1972 2002
VIN 2581641
ExCUSE ME BUT -
you say your carb ia a DGAV 33B1 ??? please explain ????
'64 R27 250cc #383851 18,000m
well, there is a stamp on the driver side of the carb, down at the bottom...it says DGAV and in some bigger letters next to it it says 33 B 1....
I have no idea what the 33 or the B or the 1 refer to.
I've talked to a club member (another O2 owher) here in Houston and he tells me that the "A" in DGAV designates "aqua", meaning Water Choke.
The thing is, there are no water lines coming in anywhere to this carb. There is only a single electric wire hooked to the round, cream-colored plastic piece on the valve-cover side of the carb.
Could it be that the carb was modified to be an electric choke? On the other hand, there are a few loose wires coming out the same wire bundle as the single wire that hooks to the plastic solenoid.
Yes, I'm clueless
1972 2002
VIN 2581641
Previous owner may have done that.
For your rebuild kit, it may not matter anyway whether its water ot electric.
'76 2002 (Sold)
