Anyone have a bullet proof fix for the shift linkage?
Do you have a permanant / bullet proof cure for the somewhat vague and troublesome shift linkage? PLEASE let me know what you have come up with or who sells a cure for this "common cold"
Thanks, Jim
jimfroula@yahoo.com
When ALL the bushings are in good shape and the bolts are tight, the linkage works great.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
I have a lot of shifter buzz, despite all new bushings, recent trans. mount, etc. Anyone else have the same problem? Also, what short shift kits work well? I'm looking to avoid the notchy feel that plague so many aftermarket kits.
.......the 'trick' is to
replace all the 'wearable' shifter
bushings,and mounts, every 20 years or 50,000 miles,
which ever occurs first.
'64 R27 250cc #383851 18,000m
As the others have said, if you replaced all the wearable rubber and bushings it will come together well. One more thing that DOES make a difference is that round foam pad. It needs to go UNDER the trans tunnel, not on top. By putting it under, it snugs up the linkage assembly tight against the sheet metal (the tunnel) and takes away any remaining sloppiness.
I had a repair shop install a tranny for me a few weeks ago and when the put the linkage back on, they put the foam pad on top (inside the car) where it does no good. I put it back under and it and it made a big difference.
1972 2002
Verona Red "Happy Face"
VIN 2581641
1999 M Roadster Alpine White, 1999 M Coupe Alpine White
