is uninstalling a differential as easy as...
as undoing the half shafts and the driveshaft. then pulling it out.
The differential also holds up the rear endge of the subframe - if you just "unbolt" it - the subframe will lean down considerably and stress out the bushings at either end toward the rear of the car. My advice is to support the subframe with a floor jack before pulling the diff carrier bolts / nuts. I had a bunch of photos of a complete rear suspension overhaul on Emily - maybe Tim in MD can throw some up here for me (Tim?....you out there????)
Paul Wegweiser
