relatively minor mods. Check the board's archives and/or go to Rob Torres' "2002Autohaus" web site--he (among others) has a kit that gives you all the mounting hardware (and a shortened shift linkage) to bolt the 5 speed into your '02.
Many folks have done it--mine will be underway shortly...
cheers
case 5 speed isn't too bad, long as nothing is broken and the synchros are OK. How many miles on the tranny?
Sorry--it's 2002Haus, not 2002 Autohaus. That's whatcha get doing things from memory!
68k on the trans coming out of a wrecked bmw
Make sure it's an E21 - 5 speed with a 3 bolt ouput flange rather than the 4 bolt. The guibo is much stronger, will take much more abuse. The 2002 4 speed has a 4 bolt configuration. However, you'll need to have a 3 bolt flange welded to your current driveshaft but that can be done when you have it shortened.
Metric Mechanic has a wack of info on this subject including complete conversion kits if required. Give them a call, they're very helpful.
Look under 5 Speed Conversions...
http://www.metricmechanic.com/tabcon2.html
1975 - 2002 - Sabine - Jade
2010 Toyota Matrix XR
Remember: RACECAR spelled backwards is RACECAR
I'm doing a 5 speed conversion this spring along with a 3.91 LSD. Here's my R6... Have fun!
