After about a 3 year absence (engine blown)... I put in a new(used) motor last weekend and finally got it started last night...
Started up and I just had to adjust the timing and idle by ear and it's running fine now.
One question, there seems to be a burnt/fuel/carbon smell that my clothes absorb after I drive it... is it running too lean?
This has been sitting in my garage for 3 years... now it will enjoy the fresh air!
71 2002
90 E30 M3
99 E39 528i
Oh.. and the dent on the passenger door was from my Yamaha YZ250 that fell over on it... I did not want to see the damage until I took the car cover off of it 2 weeks ago.... :(
71 2002
90 E30 M3
99 E39 528i
Beautiful car. I am jealous.
If you spent so much time on the car, please take the time to use a timing light and a tach to tune it. Trust me it will be worth it. The smell you described does sound like it might be a little lean, but if you smell them on your clothes after you drive, that is bad. That suggests an exhaust leak and it is very bad for the interior of your car. You can get Carbon Monoxide poisoning that way.
Make sure you check for exhaust leaks very important.
Congrats on the car it is really nice.
light to no color - too lean
black and sooty - too rich or other fuel/oil problems
caramel color - just right
timing can affect lean/rich condition as well as air/fuelcalibration
1972 2000tii Touring #3422489
FAQ member #5
Thx for the compliment... It'll take awhile for me to get use to driving the car (no power steering, close ration steering box, small steering wheel, CR tranny (forgot where reverse was) and a STIFF ride... it makes my E30 M3 feel like a Lincoln Town car.
Here is a pic of my header... the red circle indicates seams where the tubes just slide in. It was my understanding that when the header gets hot these seams tighten up. I'm I wrong, and shoud I get them welded?
Thanks,
Robert
71 2002
90 E30 M3
99 E39 528i
Waiting for heat to expand that pipe and make a perfect seal, well I wouldnt wait for it. that joint should be welded or another type of inline clamp setup.
Sam
Patrick
No, I picked up my car from Matt a few weeks ago. I know he has another Verona O2 hanging around the shop. It looks a lot better than mine!
1972 2002
Verona Red "Happy Face"
VIN 2581641
1999 M Roadster Alpine White, 1999 M Coupe Alpine White
there were 2 nice verona roundies - one a tii - then my verona 74. weird to see that when ive only seen 5 2002s in on the road in houston in almost 3 years.
Patrick Sloan
1975 inka 2002 - 2375719
1991 325iC
2001 325i
Thx for the kind words everyone... This motor is just an interim motor until I can get my other one rebuilt. It smokes on accel but at least the car drives now :)
One thing I realized is that I am driving it now with 3 year old GAS....
needless to say it pings at full accell so I am driving it VERY slow until I can fill it with new gas... tank is about 70% full.... :(
71 2002
90 E30 M3
99 E39 528i
On the slip fit of my headers on my '68 Camaro, I used the orange Permatex sealer on the female end. I just spread around a 1/8 inch bead about a 1/2 inch from the opening. I then slipped in the mail end and secured the tabs. It seals just fine and the moisture in the exhaust does'nt squirt out due to backpressure.
Cris
Thanks,
Robert
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
weird question...what is your trunk seal like? I had a bad seal in mine and continually smelled of gas and exhaust. Someone suggested I change the rubber seal, I did so , and I'll be damned. It worked.
