PRESENTLY FROM BMW:
2002 starter motor 1.1KW 12.41.1.269.696 = $155.oo
M3 S14 starter motor 1.4KW 12.41.1.312.130 = $171.oo
and support bracket to block 12.41.1.308.480 = $9.20
'64 R27 250cc #383851 18,000m
i bought a bosch rebuilt m3 starter for a little over 100 on ebay
Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on
i can get you a new oem s14 starter for 136.00 but shipping would kill the deal i think
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
I just bought an s14 starter for $140.00.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
those e28 starters are little beasts but how long do the m3 starters last?
I had an M30 starter in my car. The size is hardly larger than the S14 starter, as well as the weight just being a smidgen more... But the kicker is that i found mine at a junk yard for like 10 bucks. Way more bang for the buck than the S14 unit.
Cheers,
Jonas
I tried the E30 M3 starter on my 02 and it grinded the flywheel teeth everytime I tried to start it... after the 2nd try it worked... I eventually removed it and put the old starter back on...
The S14 was much smaller and lighter though.
71 2002
90 E30 M3
99 E39 528i
My stock '76 starter was ailing, and can probably be rebuilt easy enough, but I found a rebuilt M3 starter on ebay for ridiculously cheap (I guess nobody was watching!). So, I installed it and have had no issues whatsoever, except for the install mod. The M3 starter would not attach to the support brace like the old starter, so I drilled another hole and sized a bolt w/nut to give support in the rear (I see where cd gave a p/n for the bracket...I wonder if that will fit better?). The starter bolts on the block & housing line up perfectly.
The M3 starter is much smaller, lighter, and more powerful. "Malaga" starts like nothing else...and he has points too! Sweet mod..highly recommended!
Mit freundlichen Grüßen
John Weese
'72tii "Hugo"
'73tii "Atlantik"
'74 '02 "Inka"
'76 '02 "Malaga"
'72tii engine VIN 2760081 - waiting on a rebuild
"Keep your revs up and watch your mirrors!"
(nt)
1971 Sahara, 1972 Inka tii with Alpina A4 Injection. Both cars have too many upgrades for the "signature" square. 1987 M325ic daily driver( all E30M3 except chassis).
