I have a 74 2002, with new tires (6 months), new tie rod ends, new front wheel bearings. Front end alignment 3 months ago. My adjustment on my steering box has 3 or 4 more complete turns to go. (I have been adjusting the steering box by a quater of a turn every day for about a week) with no real results?
Has anything ever been done to the steering/front suspension? Call Max and order all new busings, ball joints, tie rod ends
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
---==! DANGER - ACHTUNG !==---
DO NOT DRIVE THAT CAR !!
locate the worn, broken, missing, loose,
about to fall off parts before driving
one more mm !!
jack up fron of car and start feeling
for any play in tie rods, steering link,
idler arm, suspension arm bushings, loose
mounting bolts, struts, loose wheel nuts,
rusted out frame rails or subframe,
broken steering gearbox mounting
bracket/subframe??????
AND BETTER look at the steering box!
sounds like your 'adjusting' in the wrong
direction! -if it's too 'tight', that can cause the
steering not to center freely causing sever
wandering ...............?
'64 R27 250cc #383851 18,000m
  • Administrators
Check the steerinf play while the car is stationary. There should be little to none at the center and a bit of play with wheels turned all the way to either side. BUt you problem is probably destried bushings or a loose nut.
steve k.
Get your 2002 FAQ merchandise from 2002FAQ Store
