I did a compression test last night on my engine. I got the results as follows 150,130,155,155 -
The second cylinder is more than the recommended 10% difference on the other cylinders. What kind of symptoms should I be able to see with the engine running comprssion like this?
Regards
Callum
'Old Blu' the 1974 fjord BMW 2002.
"your my boy blu!"
adjust the valves COLD to 0.006"
change the oil and filter - 20w/50 or 15w/50 oil only
drive 80mph for 1 hour
re-test compression on warm motor
crank motor with strong battery and
holding throttle WIDE open
report back
'64 R27 250cc #383851 18,000m
Uhhhhh....Ummmmmm I've got a dumbass question.....can you tell me how to do a compression test? Please?? I've got 30 year old tester, but no idea how to start...
Brian
report back
Or, you could drive 60 in 3rd. It is easier to keep a license that way. Same result. Work those rings hard and see if they decide to seal up.
try a little oil down the spark plug hole-
if it comes up, it's rings.
Apply compressed air to it at tdc-
if the carb hisses, it's a leaky intake valve,
if the exhaust hisses, it's a leaky exhaust valve,
if the radiator hisses or bubbles, it's the head gasket...
if the oil filler hole hisses, it's the rings... or possibly (in an odd fashion) the head gasket...
fwiw,
