In every post I read, C.D. reccomends using MarvelMystery oil to stop the smoking.
DRAIN THE OIL HOT:
refill with 1 qt MARVEL MYSTERY oil
and 3.5 qts 20w/50 oil and new oil filter
drive it for a nonstop trip 200 miles and drain
change oil and filter again and refill with 20W50
or 15w/50 MOBIL 1 and report your findings (sightings)
after another 100-200 miles of driving.
Can I save money by adding the Marvel to my old oil, and changing it 200 miles later?
I'm assuming the Marvel softens/cleans the valve seals and other engine parts. Is this correct?
I think its worth a shot. Normally, it will only smoke if I close the throttle at 5000 RPM , but one day it smoked everytime I closed the throttle over 3500 RPM. It hasen't done that since.
I'm going to college in the fall, and will have another car for the hard highway driving, so I don't want to rebuild the head.
Thanks again
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
Not only is that Oil a Marvel but its also a Mystery
TRUTH IN ADVERTISING!!!
The only honest product on the shelf.
DO NOT QUESTION IT
So obviously I"ve got no idea, but I put some in my generator and it does keep the valves from building up carbon. Who fricking knows why.. its a marvel.. A MYSTERY!
car sits 6 months a year,no problems with pistons seizing in th k-pump. Lubes everything. Also add it to the gas in my 1969 IH garden tractor,which has a motor thats never beem apart. MMO rules
Rastadog ( Alex) 73 Tii, 2018 VW GTI with 3 pedals.
I don't see that happening. That's like 3-4 hours highway!
Is that a requirement for the benefit?
My '76 is a ~daily 'round town driver.
'76 2002 (Sold)
2002 Subaru WRX Wagon (at least it's a 2002)
especially after reading the other thread about Marvel Mystery Oil. Check out the other thread. It may answer some of your questions, especially about why it should be added before a highway trip. I believe you want the engine to get nice and hot.
Although, if it cleans as well as synthetic oil, I'd be worried about oil leaks.
  • 2 years later...
I use it for that at work non stop for many issues. we import, test, and rebuild Japanese longblocks. as the tester I run them on a bench with a natural gas carb and my own manifolds. into the cyls 50/50 with lacquer thinner (in a squirt bottle through plugs), I crank em over by hand and work it into the rings and valves, then I spin it over & spit out all kinds of carbon and sludge. put plugs in it and fire it up. wide open throttle 3 or 4 times snapping it shut. usually only takes one round, I've seen compression go from non running 30 all the way to a full 220 lbs in 6 minutes... when you take the plugs back out, the pistons are usually shiny & clean. it seems to almost disolve into oil even without mixing thinner into it.
I use it all day and it's still a mystery..
Tim. 2 daily drivers
His: 68' 1602-
Hers: 76' 2002 auto-
  • 11 months later...
