The BMW specification for your transmission is GL-4 80W
per BMW Repair Manual and BMW Owners manual
BMW - MINI now offers a 5 Litre (1.32 U.S Gal.) bottle available from any BMW - MINI dealer. Part Number 83.22.7.533.818 , suggested list price $119.00,
MTF-LT-3 70W API GL-4
This is also the gear oil for MINI Getrag 252-5 speed and 285-6 speed
produced from 07/2004, see MINI SI M 00 02 02 March 2005
other available GL-4 gear oil:
GEARPLUS® SAE 80W-90 GL-4
WARNING:
All modern gear oil available today in local retail outlets is GL-5 grade. GL-5 grade gear oil contains sulphur compounds that attack brass and bronze. BMW transmissions and final drives made before 1992 contain bushings and thrust washers made of these metals. Any brand of gear oil that is GL-5 rated will attack bushings and thrust washers.
Pennzoil Specialty Gear Oil For Applications Requiring GL-4 Performance:
PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT is specially formulated to meet the unique requirements of API GL-4 service in manual transmissions and transaxles of passenger cars, light trucks and SUV’s. PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT is blended from select base stocks and additives that yield a lubricant of exacting quality. This product is compounded utilizing specialized extreme pressure chemistry that provides protection of gears and bearings without being corrosive to bronze components. It contains foam suppressants to prevent wear, which can be caused by lubricant foaming and aeration. Effective rust and corrosion inhibitors protect metal surfaces from the effects of water contamination from condensation and the operating environment. PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT resists the formation of varnish deposits on synchronizer components, thus assuring long, trouble-free operation.
PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 gives the full protection of an SAE 90 under hard driving conditions while providing the flow characteristics of SAE 80W that are necessary during cold weather start-ups. This offers maximum lubrication and gear protection over a wide temperature range.
PENNZOIL® GEARPLUS® SAE 80W-90 GL-4 GEAR LUBRICANT is designed for manual transmissions and transaxles of both American and import vehicles. It is formulated to be compatible with “yellow metals”, such as bronze, found in synchronizers and other transmission componenets.
BENEFITS:
• Meets the performance requirements of API GL-4 Service
• Will not cause glazing of synchronizer components
• Excellent thermal stability
• Outstanding extreme pressure and antiwear protection
• Prevents rust and corrosion
• Inhibits foaming and aeration
'64 R27 250cc #383851 18,000m
My 71 manual calls for Gl-1.
Also see Amsoil MTfF Synchromesh Transmission fluid, sells for between 7 and 8 bucks a quart or MTG Manual Transmission fluid, sells for a bit over 8 bucks a quart. Complete specs on line.
Used their products since 1978 in my BMW.
A lot of people on here use it and from what I can gather, it should be aOK too. I haven't had occasion to use it. It's specs look good.
I've always used ATF in my manual gearbox. Never had a problem! We used to use it in our E21 racecar as well...
1975 - 2002 - Sabine - Jade
2010 Toyota Matrix XR
Remember: RACECAR spelled backwards is RACECAR
it's in every gearbox that will hold it... as it manages to leak out of Jenn's 5- speed at a prodigous rate!
But it comes out of the racecar's tranny spanky clean every fall..
I've been using it for more than 20 years. Have put over 100k miles on at least a couple of trans using it. Currently have it in 6 cars.
BMWCCA #2762
72 2002/71 2002ti, 67 2000CS, 2x 72 3.0CS
86 635, 2x 05 330Ci ZHP,
'11 Corvette Grand Sport
ATF! I knew I wasn't alone!!!
