Can some one help me identify this part. i believe its part of the emission system. its located right behind the alternator just above the oil filter. (see attached pictures). It applears like some kind of a valve. on the top it looks like a hose should be attached to it. i believe it goes into the air filter box. on the side there which is threaded hole about the size of a quarter. i think something should be screwed into it, what is suppose to go in it, i have no idea. i had a 1974 carburetor install on my 1975 02. this thing is making noise like there is a leak in the exhauset system. what is the name of this part and where can i get it. if i switch to a 32/36 weber what happens to the hose from this part. thanks
I take them off and I have used the steel return line as the feeder line . takes alittle doing but ....
tii touring in 75, on the Abahn in Europe 1975 to 1978, 74 Red Baron 1986( still with my kids)
Green culb racer and Malga Auto left the family
Left w/ a 1976 beater/5 sp/AC in 2004 not on the road yet & Its All I have left
rob,
thanks for the info. you are right. it is the diverter valve. since my car no longer requires smog check, i will be taking off the belt to the air pump. i suppose that will stop the flow thru the diverter valve. which one is the steel return line if i decide to go that route?. thanks
