How to remove Inst. Cluster? T-Stat Question.
So it seem that the problem with my o2's temp guage twitching may be a problem with the grounding. Well I do appreciate all the advice regarding this problem, but I was wondering how do I get to the Instrument Cluster? How do I remove it? I have yet to really look into it, but I was wondering if you guys could give me a clue.
Additionally, since I am having this problem with my temp, I'd might as well look at my t-stat. Is there a particular temp that I should get? Thanks....Dave.
Remove covers under steering wheel, reach uder and remove 2 round knurled bolts, loosen speed-o cable and wiggle cluster out.
have fun, might as well take it apart and clean it while you have it out
kind of a simple set up.
FO 2573825
1971 2002, 5-OD, Recaro SE, BBK, 90Amp Alt, Turbines, VDO, Hellas, BD belts, LED Tails, 10 Foot DD
are grounds he has added. Sometimes this is the only way to cure twitchy gauges.
Nice photo
1972 2000tii Touring #3422489
FAQ member #5
I'll climb under there tonight if I have a chance. Not a good feeling driving around with the temp guage reaching for the sky like that. Like I said the car seem to be running fine, the tach seem to be a bit twitcher since this problem arose. I'll let you guys know once I've grounded everything out if it was the bug.
Talk to you later...Dave.
I went though the same EXACT anxiety years ago. Temp. creeping up. Needles fluctuateing when the turn signals OR headlights on,etc.
The pic. I took with the added grounds solved EVERYTHING.
AKA: "Captain Obvious"
Drivers:
'72 '02
75 Opel Ascona
e21
2-e30's
2-e28's
15+ parts cars
http://myworld.ebay.com/ebaymotors/fosters.3
