Oil Pressure gage
Are any oil pressure gages available that actually fit the 12mm by 1.5 thread in the oil pressure switch location? I bought a sender cheeepo (Sunpro)and it had a 10mm by 1.0 thread for about $15 I tracked down an adaptor to make it work and it was about $25 just for the adaptor fitting. Thanks for any help
I bought one from O'Reilly Auto. It was a special order, but it only took 1-day and cost less than $5.
e46-330ci, e46-325ci Vert., e36-328is, e30-325is, M20-2002, K110, K75, '71 Jeepster Commando
Hi you might look into vw cabrio's and GTI's many had VDO oil pressure gauges from factory and have sensors that look very similar to the one's used in 02's. I would say I'm 95% sure the sending units from vw would thread into the 02 plus it would have a factory appearance
The best solution is to buy the adapter and the two post sender. One for the idiot light, and one for the gage. I know this ain't cheap, but it works and that's the real reason to care about oil pressure right???
BigDog
'76 2002
  • 3 weeks later...
BigDog
'76 2002
Hmm, I bought the 0-100 gage, and I dont see a 2 post sender for it. Doh!
Time to make a custom transistor circuit to control the idiot light based on voltage.
