should i be worried about this
how do i get rid of this and what is happening?
i have no idea. i bought the car like that, i assumed it was stock
i like the heat shield....did you add it and know where to find one like it?
I just bought a heat shield from Bavarian Autosport ....bavauto.com.... for about $15 bucks.
I believe the heat shield exhaust gasket is from the 318i application of the M10... the E30, IIRC. In any event, they are commonly available for $25... or so.
Chris B.
'73 ex-Malaga
Well, it is not a Good Thing, whatever is causing it. Possible causes are leaking exhaust studs (only some of them can leak... I can't tell from the pic if the stud above that position is one), loose plug, or leak in the valve cover gasket. As has been suggested, get a mirror and see what you can see. If necessary, wipe off the grease that will have collected on the head, take a short drive, and then look again. It is possible for oil on the exhaust manifold to catch on fire.
Chris B.
'73 ex-Malaga
I got one from bmpd.com for $14, they really are a nice little addition + they are light weight.
As for the oil spot, lose spark plug maybe?
Ca '76: Sahara / Korman Stage I
That gasket only comes on a 318i. All E21's had the 4 piece deal like an 02.
