Hey guys,
It been a week and no sign of my keys for the doors and ignition. Luckily the car was not locked but I still dont have a key. What are my options at this point? Thanks
Take your switch housing out and take it to a good lock smith and they can make you a key. After you have the new key take your door lock cores out insert the new key and file off any of the tumblers that are sticking out, now all your locks match.
Trying to buy back my
75 Sahara
Pertronix, 9.5:1, 294, 40mm Solex, 5 speed, MSD
75 Sahara
I think the key code may be on the door handle tumbler. Try doing a search.
Having a locksmith make a key based on the door tumbler may be easier than pulling the ignition switch.
Mike needs to chme in here...
Good luck!
Ray
Ray
1. get back behind the ignition lock switch housing (you might need a mirror) and look for a little white sticker on the diecast housing that holds the ignition lock. The sticker usually has a 4 digit number preceeded by a "W"--that's your key code. If your ignition switch key also worked your doors (how the car came from the factory) and if the locksmith has or can cut the key from the code, you're in business.
2. If the sticker is missing and door/ign locks match, it's MUCH easier to remove a door handle and take it in to a locksmith (to remove the ignition lock, you'll probably have to pull the entire steering column due to the breakoff bolts that hold the lock assy to the steering column and that's a real PITA--or drill out the pin that holds the lock cylinder in its housing, also a PITA and a bit tricky to not damage the lock cylinder).
Of course if the ign is different from the door locks, you're gonna have to remove a door handle anyway. If this is the case, now is the time to have the locksmith make a single key work all three locks.
Good luck--ain't hard, just time consuming...BTW--make a spare key and put it in a safe place!
cheers
and the tii touring has been setting for 3 years no Keys
AAAH the lawyer , the son
tii touring in 75, on the Abahn in Europe 1975 to 1978, 74 Red Baron 1986( still with my kids)
Green culb racer and Malga Auto left the family
Left w/ a 1976 beater/5 sp/AC in 2004 not on the road yet & Its All I have left
Thank you for all the advice. I dont know what the hell happened with the key. I have been searching for a week. Im gonna go out now with a flashlight to try and find that sticker. And yes the locks on the door and ignition match. Thanks again
Yah I just went and looked and didnt see a white sticker with the key code on it. Going to call the locksmith tomorrow and see how much its going to cost. For some reason I feel like Im going to find my old keys right after I have my new ones made...
Hey guys.
So I decided to go with keys for classics. They can cut a key for you for $13 by code. Im so excited! I cant wait to drive my car again
Hey guys
So I ordered my key through Keys4classics.com and it arrived today! It also works great. Im so excited. If any of you need a key replaced or made definitely go through these guys. Thanks for all of your help
