What are some the ways you guys like to clean your engines? My car is clean on the out now i need it to match on the inside. What are some the goodies out there that i can use??
TIA
Miko
I did my engines with por-15 marine clean .. you spray that stuff on and let it sit and then hit the thing with a pressure washer
years of gunge gone!
eletrical bits with platic wrap. Spray on the simple green, let it soak little while, then spray off with garden hose - not too much presure.
Paul in Richmond
'70 Chamonix
'85 535i, 2000 R1100R
on tv. Then there's also the steam shark.. Hmmm.. I love all those gadgets on tv.. remember "GS27" it was the miracle scratch remover. Yeah I always ened up gettin my money back. Thanks for the input guys and gal, I'll try it the old fashioned way with plastic and water.
I hit a greasy engine with aircraft solvent through a special nozzle that mixes compressed air with the solvent. Doesn't hurt paint or engine metal and the oil and grime just falls off, be careful not to hit anything that you want to keep grease on though. Best if its just used on just the engine block and oil sump.
Works great! Just a few minutes and your engine is squeaky clean.
Ca '76: Sahara / Korman Stage I
