clicking noise 2x revolution from right rear wheel????
Car is fine forward of the diff. (not driveshaft). Never messed with rear stuff incl. driveline. Just returned from a winter weekend drive to hear clicking noise as if one of the shoe springs let go. Any thoughts otherwise? I can't really get into things for another two weeks and am hoping all is safe to drive????
PLEASE JACK UP THE REAR OF THE CAR BEFORE DRIVING ANYWHERE ELSE!!
GRAB THE WHEEL AT 12 AND 6 O-Clock and no wiggling should be felt
make sure the wheels turn freely with no scrapping noises or resistance
try wiggling also holding at 3 and 9 O-Clock
while rotating the wheels - listen for any noise from the axle joints inside the rubber boots - look at the boots for tears or grease loss.
A brake shoe spriing could have come loose - remove the rear tires and drums and inspect for broken /dislodged bits
do not just drive with your radio turned loUDER - diagnose
the noise before a wheel passes you down the road - or worse
'64 R27 250cc #383851 18,000m
do you have hub caps on the wheel? Take the hub cap off and see if the grease/resivoir cap thingy is floating around between the wheel and the hub cap.
~Vroomer
1969 BMW 2002
1972 BMW 3.0 CS
2003 BMW Z4 3.0i
2007 Jeep Wranger X with all the trimmings
My bet is a worn axle spline. If it is repace both spline parts male and female. A temporary repair is to use locrite thread repair on the splines.
If it sounds/feels like you have a midgit in the trunk, the castle nut is probably loose. I could also make a "rubbery" scraping noise.
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
