Is the distributor wired from the coil after the ballast resistor to drop the voltage ?
Working on a car that has been gutted and sat for years. Is their an online wiring schematic anyone knows of ?
The distributor is wired from the "-" side of the coil. The ballast resistor is in series between the +12V power source and the "+" side of the coil.
Dunno if anyone has a wiring diagram posted; however, if you post the year of the car and the wire colors about which you have questions, someone will likely help you out.
Chris B.
'73 ex-Malaga
Presuming you need one... what kind of coil do you have?
Also, there is nothing unique about the BMW resistor. Many cars use a ballast resistor, and I would bet that you can get a compatible (correct resistance) resistor for ~$10 at your local auto parts store.
Chris B.
'73 ex-Malaga
