Hi all, I am getting ready to place my order for the goods to rebuild and rejet my 32/36 --And I have some questions:
I have a Water Choke (DGAV?) now but I recently purchased the Weber kit to convert it over to a manual choke. Because of this, which rebuild kit do I purchase along with these bits from the prescription? :
Float Level 40mm
PRIMARY
idle 60
main 140
air correction 145
SECONDARY
idle 55
main 170
air correction 175
Thanks in advance,
Ben
--> 1968 2002 <--
....the 'rebuild' kit is the same , water choke or manual choke.
all the jets are available from ecxellent Pierce Manifolds WEBER
supply in Calif - see their site and link below.
personally, I prefer a well adjusted water choke, but manual pull
is ok provided one understands air/fuel mixtures, motor running 'heavy'
feeling, 'four-stroking' and you lean it out in the correct time.
The jet sizes you list are my suggestion and I promise excellent improvement and smooth power delivery - But !
adjust valves, set dwell & timing with a timing light, have good compression, freely operationg linkage that is opening fully, before hand
for optimum results. Have Fun & Protect Yer Eyes.
[/url]http://www.piercemanifolds.com/products.htm
[/img]http://www.roadfly.org/bmw/gallery/photos/photos-10-2003/28-7309479.JPG28-7309479.JPG
'64 R27 250cc #383851 18,000m
How do I know if I have brass or plastic? Can they tell from my carb #?
My 68 2002 has no provision to hook up a water choke, it seems.
previously in SoCal, I guess they didn't care too much about chokin'
Thanks for the advice!!
Ben
92.3237.05 DLX B
Weber 32/36 DGV, DGEV, DGAV
Rebuild Kits for carbs with Brass Float
1. These special deluxe rebuild kits are not to be confused with the many “cheap kits” on the market.
2. The DLX B kit includes:
a. Air filter gasket 99005.069
b. Carburetor top gasket (float bowl) 41705.035
c. Mounting base gasket 99005.068
d. Viton tipped needle and seat 79519.200
e. Accelerator pump diaphragm 47407.355
f. Power valve diaphragm assembly 57804.052
g. Fuel filter 37022.010
h. Washers, O-rings, split pins
i. Throttle shaft seals 12750.085
j. Genuine Weber float setting gauge 98.0281.00
k. Carb exploded view and parts list
l. Float leveling instructions
m. Idle setting procedures
92.3237.05 DLX P
Rebuild Kits for carbs with Plastic Float
2. The DLX P kit includes:
j. Genuine Weber float setting gauge 98.0284.00
--> 1968 2002 <--
you have to remove the carb top section to be sure:
float_1.jpg[/b]
