Does anyone have a diagram for the fuel system for a tii? I've got a leak I'm trying to troubleshoot about halfway up the car on towards the drivers side. A regular 02's diagram will work if they're the same around this area.
you may be able to see it on realoem.com.
It sounds like your fuel suppy line is leaking. The fuel suppy line is a metal line that runs the length of the car on the driver's side from the rear wheel well to just fore of the front wheel. You can see the front end of this pipe in the engine bay. It has a rubber or cloth braided line attached to it that runs to the fuel filter.
These metal lines rarely fail, just ensure that the fuel is not running along this pipe due to a leak or failure someplace else.
In the URL attached, the pipe is #13 and it indicates that pipe is NLA. Some report they fabricate this pipe out of commonly availbe pipe or tubing from hardware stores.
http://www.realoem.com/bmw/showparts.do?model=2583&mospid=47141&btnr=16_0388&hg=16&fg=15
1972 2000tii Touring #3422489
FAQ member #5
