Fuse Numbers and Sizes ?
Can someone point me to a table that will show what fuctions are on each fuse, and what the fuse size should be (pink/white/blue) ? I have tried tracing it on my wiring diagram, and I am cross-eyed from the exercise. The car in question is a 1973 Tii.
This would be a good addition to the FAQ section.
Thanks again
Chuck
P.S. My electrical problem was actually a bad fuse (the fuse head was cracked, but it looked fine). FYI, if your wipers, horn, and brake lights don't work... check fuse 12
Chuck in NC
taken directly from the sticker or my 74tii
1. cigarrette lighter/auto antenna..............16a pink
2. hazard, clock, glove compartment light..8a white
3. rear window heater..........16a pink
4. heater blower...16a pink
5. windshield washer/wiper, stoplite...16a pink
6. backup lights, radio, flasher system, horn...8a white
7. park lights, tail lite right....8a white
8. License plate ilumination, instruments, rear fog lite, parking light/tail lite left....8a white
9. low beam left....8a white
10. low beam right..8a white
11. high beam....16a pink
12. electric fuel pump, autho choke, warning fuel, temp indicator, tach, brake fluin indicator, handbrake..8a white
Chuck,
Here's a sticker for 1973 and up, from the Wallothnesch site. It might be a good idea also to sand the fuse connections at the fuse box also, just a little to make a really good contact.
Tim
'69 2000
I have found some discrepencies between the years.....I have an original '73tii fuse sticker that I'd be happy to share the info with you.
John
Mit freundlichen Grüßen
John Weese
'72tii "Hugo"
'73tii "Atlantik"
'74 '02 "Inka"
'76 '02 "Malaga"
'72tii engine VIN 2760081 - waiting on a rebuild
"Keep your revs up and watch your mirrors!"
