I think my "Boxed" non-tii trailing arms turned out pretty good. I cut out 16-gauge sheet steel and formed them to fit and a friend of mine tig welded them in place. Now I need to drill a hole for the brake line and por-15 them inside and out.
Phil/Bomb Guy in Colorado
2002 E46M3
2002 E46 325 xi
1991 E30 325ix
1970 2002 M2
1966 Mustang
They look great. Did you weld them in a jig? Make sure they still fit before you go any further.
John
1665778
non-boxed trailing arms ever flex or break.
Are you building a Torque monster?
I wonder if there is some kind of lazer measuring
system you could hook to your g-analyst that
would indicate changes in alignment of a lazer
and a recepter.
Someone needs to give this to Mike Valentine
to create.
Ray
Ray,  Current BMWs, 1973 BMW 2002, Turkis, and 1997 BMW 318i 5sp avus blue.  Drove a lot and sold over the years, in reverse chron.
     1997 m3 coupe silver, 1998 318ti red, 1996 318ti red,
     1973 2002 Agave, 1971 2002  GM brown
I have never heard of one failing, but if your using polyurethane bushings and sticky tires on the track, I think there could be some flexing. As for building a torque monster, "no" but I am installing an E30M3 engine in my car pushing around 200hp.
Also, I have sent my stub axles out for cryogenic treatment to make them harder. I have heard of them failing in high hp cars.
2002 E46M3
2002 E46 325 xi
1991 E30 325ix
1970 2002 M2
1966 Mustang
I have seen 2 break and had one crack. These were on race cars so the loads are much higher than a typical street car, but they do flex and they can break. Crack was in the weld that runs under the hub.
As for the brake line, found it easier to weld a bracket on the top of arm rather than run through the inside. Not what the factory did, but it makes easier to connect the line.
