I was just reading through C.D.iesel's 32/36 prescription, and noticed he says to "install a new mechanical advance distributor". Does that instruction hold true for stock engines as well? I had thought that the vacuum advance was better for a stock engine, and that you only wanted the mech. advance with higher compression and a hotter cam.
What's the verdict?
Aaron Heinrich
Portland, OR
'72 Sahara
http://www.flickr.com/photos/heinrich02/
What's the verdict?
That is all true, but insignificant. You can't tell the difference without a dyno, a correctly timed mechanical distributor will be just fine.
Tom
Something always leaks.
correct-toe-mund0 Trent,
bottom line - a new mechanical distributor
produced tons of smooth pulling power,
steady firing of all 4 cylinders.
Toss out that 30 year old , worn out, uneven
firing, inoprative advancing vac-distributor.
'64 R27 250cc #383851 18,000m
