Is this a tii manifold?
..and is it worth anything?
It appears to be in good shape, manifold, downpipe, the heat deal might be a little beat up.
yes and no
heat shield indicates a carb / My Tii (72) heat shield is very different.
Manifold and all are good for a mild motor (sorry CD). has no smog fittings that I see,
best Iknow same as a tii
tii touring in 75, on the Abahn in Europe 1975 to 1978, 74 Red Baron 1986( still with my kids)
Green culb racer and Malga Auto left the family
Left w/ a 1976 beater/5 sp/AC in 2004 not on the road yet & Its All I have left
Dave Varco told me once that this is the '74 (?) carb version manifold that looks almost like a TII but has the hole drilled in the plug for the emissions junk (where the actual TII manifold has the plug blanked off). He also also that for flow it's somewhere in between the big squarish things with EGR spouts pointing into the exhaust valve outlets (like the one that used to be on my '72 std), and the actual TII item. So no, it's not actually a TII manifold; but it's better than most the standard manifolds.
Aaron Heinrich
Portland, OR
'72 Sahara
http://www.flickr.com/photos/heinrich02/
without big ugly hole .
no hole same same best I know.
1600 manifold may be smaller
These if you hog out per metric mechanic they are great on stock mild motors
been at this since the late 60's
