i've had a friend over the last 3 nights helping my hubby take the thermal reactor off my 76...all bolts are out except the bottom 2 closet to the back firewall....
try as they may, those 2 bolts won't budge...one's rounded and the other is about to go round
tips @ techniques...anyone...everyone
Vise-Grips, and Wurth Rost Off Ice are your best friends here.
Al
and a ton of patience.....
California owners of 76 cars would be interested. I might be interested if it is in decent, working condition... just in case. Brian Foster
i have everything...it was working the last time i had to smog it in lA but that was 8 years ago.....the car's been park'd inside since then, driven just enough to keep it lubed...
if i can round up all the pieces, you're welcome to them...or anyone else that might....i don't need them
give me your email or send it to me at esty_lcrx at yahoo and i'll try to get all the stuff together and drop you a line when i do
- - - DREMEL POWER ! - - -
cut the nuts and bolt heads gently
'64 R27 250cc #383851 18,000m
another cast iron exhaust manifold, take a spare stud and nut to mock up where they sit in relation to the manifold when installed. You'll discover that by removing a small amount of metal (use a grinder) from the manifold casting in the vicinity of where the nut sits, you'll be able to get either a box end wrench or a socket onto those nuts.
It won't help you this time, but it sure will the next. I just went thru this myself--those lower nuts are a PITA.
cheers
Just got a rusty bolt remover set from sears. They have a few different sets. They have a reverse screw type of locking mechanism that grabs the bolt when you unscrew it. I haven't tried it, but I got a rounded bolt on a olds 442 455 exhaust manifold. Good Luck
I was there for the Al Canuck rost off ICE manifold incident on the other end of the Rachet. Being a Dane of Keebler Elf proportions rost off ice made the job possible.
It truly is the best penetration oil ever invented.
