Can 32 21 1 113 178 be substituted with a grade 8 or 10
bolt? It's the bolts that need to be safety wired. They hold the strut housing to the pitman arm or whatever it's called. (the thing that the ball joint bolts to)
...plenty of them in stock in the USA = just order from any dealer,
BMW Car Dealer. do not substitute for yer safety. Death is perminate.
32.21.1.113.178 = $7.10 each
'64 R27 250cc #383851 18,000m
I just paid $30 to have them overnighted because I need them by tomorrow. I would have thought a good high grade bolt with some locktite would be just as good.
then there is no way to know for certain that you are getting the grade you think you are getting. there are tons of knock off chinese made bolts that are labeled as grade 8, etc...that aren't as they say.
i recently did that same replacement and thought about getting regular high grade bolts...until i did some reading about the crappy chinese phonies.
i got a full set of the OEM bolts from the dealership for $35. in the end i figured it was better to be safe than sorry.
'74 turkis 2002ti(-i)
  • Administrators
they are actually higher then 1grade 10. get them from the dealer or any supplier, safety wire and do not reuse them if you think that at any point in their life they have been stretched or compromised or i will have to bring out the scarry pictures again :)
steve k.
Get your 2002 FAQ merchandise from 2002FAQ Store
