Final Engine Assembly and Installation Advice Requested
After some false starts and parts delays the 1973 Tii engine is now a short block. I have a couple of concerns as I start to intall the front cover,head, flywheel, clutch assembly, etc.
1. What are the common errors or oversights that I might make that would result in leaks, or other unmentionable disasters ?
2. Is there a downside to installing the engine and transmission back in the car without the head ? I think it might be easier to get it back in the engine compartment without the head, especially since I will probably be doing it by myself. I also plan to leave off the water pump, alternator, and starter. Is this a good or bad idea ?
Any advice, or first hand experience gratefully appreciated.
Chuck in NC
leaving the heater hoses off/loose... hooking up plug wires wrong..
install the engine with the head on. It's almost impossible to make sure the chain is perfectly taunt once the lower front cover is on. Don't forget to thread the Tchain through the guide rail and the head gasket before installing it.
my experience
build the motor complete less dizzy ,put motor at tdc #1 cam mark up etc
I usual put the water pump on but if you have the tranny out too no .
Put everything on except header / tii manifold
Time the pump tii and the cam and the dizzy's position out of the car
tii touring in 75, on the Abahn in Europe 1975 to 1978, 74 Red Baron 1986( still with my kids)
Green culb racer and Malga Auto left the family
Left w/ a 1976 beater/5 sp/AC in 2004 not on the road yet & Its All I have left
I also would put the head and and front covers on before puting it in its much easier to get the cam timing right and keep crap out of the works. Also when installing the front covers you'll see two small holes thru the head gasket where the head and the upper and lower covers come together, fill these hole with a dab of sealant to prevent oil seeping at this 3 way joint.
Marty
Don't worry about the world ending today,
Hell it's already tomorrow in Australia.
If u had the head milled, be sure the upper timing cover was also milled. Otherwise u will have never-ending headaches with a leak there. And I don't have to tell u it is a real pain to work on that area on a tii with the motor in the car!
Cheers,
Ray
Ray
