i have removed my rear tii seats, now i am trying to get the 635csi seats in but they dont seem to fit very well. do i need to do any fabricating to get them to fit. or do they just not fit in my perticular 1974 2002tii
will need to be done. not sure what, as i have yet to get a set for myself.
figure it out and let us know.
frank o
FO 2573825
1971 2002, 5-OD, Recaro SE, BBK, 90Amp Alt, Turbines, VDO, Hellas, BD belts, LED Tails, 10 Foot DD
You need to cut out the fiberglass rib on the back of the seat that hits the wheel well and switch the seat belt retractor and buckel end so the retrator is on the drive shaft tunnel side and the buckel is on the outside.
Marty
Don't worry about the world ending today,
Hell it's already tomorrow in Australia.
about how much of the fiberglass in the back do i need to cut out. some rough estimate would help or a picture. and if i cut this out wouldn't it make it really uncomfortable to sit in for your back?
If you cut the rib out flush with the seat back should get you to the point where the seat is sitting back far enough to fit. It will only leave a 2" wide strip off the back and you won't feel that thru the padding. But go slow and only remove as much as needed to get a fit and wear a dust mask while cutting as it makes a lot of dust.
Marty
thank you very much i will do it tomarow but also, are these e24 seats leather or vinyl. they seem leathery but i cant tell someone clarify this for me thank you
Light a match, vinyl melts, leather does not. do it on the back or underneath. Beaner7102
  • 14 years later...
Hey JohnPaul,
   Since the title of your post is “Installing 635CSI seat in a 74Tii” can you provide some photo’s of the actual “INSTALATION”? I’m in the process of trying to install these very same seats but don’t have clue about how to SECURELY place these seats.  If I can return the favor I’ll be more than happy to do that, thanks ahead.
-Noel TocaChakra Rivera
