Sign in to follow this
is it common to apply RTV behind your brake pads?
11 posts / 1438 viewsLast Reply
Im taking apart a set of pads from the calipers, and noticed some high temp RTV or some sealant behind it- I assume its to prevent moisture from entering the brake piston. I've seen this done before, and sometimes I haven't- but I haven't replaced many pads before to actually see if you are "supposed" to or not.
Any thoughts?
What color is it. I have used a product on the back of pads to quiet them. Red in color very viscous on application and dries to an appearance very similiar to RTV.
Earl
All it does is not let them vibrate under light braking.
John
(nt)
thing on the back of brake pads on a track car though, since the heat will melt anything applied and can cause problems.
even on a normal driving loop- there's enough heat generated there to kind up the piston, or cause some interference with the seals there don't you think?
rear of the pad (the backing plate) to prevent any squeal.
(nt)
(nt)
on all metal-to-metal contact points, i.e. pad backing plate to piston, backing plate edges to caliper and spring.
I wouldn't put it on brakes.
Anti-squeal compound, yes.
