Sign in to follow this
Instrument Panel
2 posts / 150 viewsLast Reply
Does anyone have pictures of the bolts that screw the instrument cluster to the car? Are there any tricks to this installation?
Many thanks,
Peter
Oakville, Ontario
aluminum thumbscrews that thread onto the two studs that protrude from the backside of the instrument cluster. If you look at the hole where the instruments go, you'll see the two small holes that accept the studs. You can reach under the dash and install the thumbscrews--but first reconnect the speedo cable--it's easier to do before bolting down the instrument cluster. Easy job once you've done it--easier to do then to describe!
Cheers
Mike
