Sign in to follow this
NE1 ever patch a windshield washer bottle? rubber cement/PVC
8 posts / 169 viewsLast Reply
I got a leaky washer bottle and they are NLA. Has anyone ever patched there's successfully? Inside or outside or both, rubber cement/PVC pipe glue/super glue/ fingernail polish(stay away from hot pink)?
Anyone got any ideas?
Chuck
(nt)
clean is key.....then use clear pvc cleaner followed by clear pvc cement over the leak...it'll melt the plastic, stopping it....hopefully, unless it's a major break
(nt)
(nt)
here's an old trick to keep that from happening--glue some foam weatherstripping, felt, etc onto the two bracket "ears" to cushion the bottle...also don't keep the bottle full all the time--weight and water pressure on the pump seals...
Cheers
Mike
over. Works fine, just don't try it on a gaping hole.
