Sign in to follow this
75/2002
2 posts / 93 viewsLast Reply
My 2002 has some electrical problems like the Horn sounds when I am turning left, or the Temperature Gauge start getting hot when I used the Turning Signals or brake etc.. What should I look for any Ideas..?
thanks
The guage problem is usualy a lack of proper grounding in the cluster. There is an FAQ article on how to run a second ground wire. The horn sounds like the horn ring or the plunger has been damaged. Pull the steering wheel and have a look. If not quit driving like a red neck (left turns only).
Sam
