Sign in to follow this
What size stud do I need? Please, no jokes, guys...
18 posts / 169 viewsLast Reply
What size do I use to hold the rocker cover down?
Clumsy PO dropped acorn nut into the space between the radiator support and front sheet metal. Replaced it with a bolt.
I've retrieved the acorn nut, but sud is long gone...
Anybody???
TIA
Delia
the same size as the studs that VW air cooled engines use to retain the oil strainer/drain plug plate on the bottom of the sump.........
(nt)
I do beleive they are 6mm, but I"m not sure of the thread pitch being 1.25 or 1.5. You'll want to pull one and take it to a fastner store to get a good match. It's easiest that way.
Now for more advice. it's nice to have a stud tool. Esp in the metric sizes we use commonly. It's like a socket designed to add or remove studs, and I can't stress enough how much better this is than buggering up threads by using the jam 2 nuts together method!
Good Luck!
Ps. I hope the P.O. didn't use the wrong thread pitch on the bolt he used inplace of the stud, or you maybe looking at a drill and helicoil operation as well.
BigDog
'76 2002
How'm I doin'???
LOL!
D
(nt)
(nt)
buy all new ones. Should take about 20 minutes to change all of them and you will have a purty leak free valve cover
(nt)
(nt)
(nt)
I hate it when the nuts bugger up the threads on the tool... Ha ha ha.
BD
The 2002 ORange parts book has the valve cover stud listed as:
07 12 1 908 106 Which does not seem to supersede to anything (could be a typo?)
In spite of that, the M10 & M30 engines (and some Motorcycles) can use the same valve cover stud:
07 12 9 908 106 which cost $0.18 each from BMW, these are what I buy.
I mention this because your parts guy may have trouble if he goes after the search like it has to be the 2002 part. My HTK has this same problem with the 02 stud, shows it as a kit NLA.
I just ran the number on a catalog search, and copied the list of applications below. Should be simple to find, just avoid mention that it's for a 2002!
Part 07129908106 (STUD BOLT) was found on the following vehicles:
114: Details on 114
114 1602 SEDAN
114 2002 SEDAN
114 2002tii SEDAN
E12: Details on E12
E12 528i SEDAN
E12 530i SEDAN
E21: Details on E21
E21 320i SEDAN
E23: Details on E23
E23 735i SEDAN
E23 733i SEDAN
E24: Details on E24
E24 630CSi COUPE
E24 633CSi COUPE
E24 635CSi COUPE
E28: Details on E28
E28 533i SEDAN
E28 535i SEDAN
E30: Details on E30
E30 318i COUPE
E30 318i SEDAN
E32: Details on E32
E32 735i SEDAN
E32 735iL SEDAN
K41: Details on K41
K41 K1200GT N/A
K41 K1200RS N/A
K55: Details on K55
K55 K100 N/A
K55 K100LT N/A
K55 K100RS N/A
K55 K100RT N/A
K59: Details on K59
K59 K75 /2 N/A
K59 K75C N/A
K59 K75RT N/A
K59 K75S N/A
K63: Details on K63
K63 K1 N/A
K63 K100RS N/A
K64: Details on K64
K64 K1100LT N/A
K64 K1100RS N/A
K73: Details on K73
K73 K1200RS N/A
K76: Details on K76
K76 K1200LT N/A
K76 K1200LT/M N/A
with aaaaaaahhhhhir conditioning. Well its just a thought at this point. finding a good one, using that as a daily driver and parking my honda .....my 02 just drinks too much gas to drive everyday. I was filling it up every other day. (no kidding)
I want to have as much fun driving but its 120 degrees out here.
How diff would it be to find a good 91 318? and where could I go for info on these cars? I dont know a wrench from a bench, so I wont be working on it. What are your thoughts? I know you had 2-older 3 series and u were searching for reliability.
email me at lisennmo@yahoo.com
