Sign in to follow this
Are there different mechanical fuel pumps available?
3 posts / 139 viewsLast Reply
I've seen pics of a style that has the inlet and outlet on the same side, pointing forward.
My stock one has the inlet pointing rear and the outlet pointing front. I like that better for hose routing.
When ordering a replacement, what brand is like stock?
Thanks
URL: http://www.zeebuck.com/bimmers/bmvseite/headlinerclean.htm
On the pumps I have seen (both '73), the cover of the pump has a screw which, if loosened, will allow to you move the inlet through 360 degrees.
Tech Trivia: if you take the cover off, you will find a fuel filter screen.
It is my understanding that the pump screen, along with any filter in the carb inlet and the screen on the tank pickup inlet, was all the fuel filtration BMW engineered into the 2002s. Except for the Tii, inline filters were either added by the delivering dealer or a previous owner.
regards,
Zenon
I always thought that there was no in-line fuel filter. There doesn't seem to be any on the books either.
