Sign in to follow this
Quarter Light Knob Question
4 posts / 229 viewsLast Reply
I have a 2002 tii and i tried to use the FAQ about the window regulator, which explained how to do remove it, but mine does not seem to remove the same way. I know that this is a very specific question, but i have been staring at this thing for the past 2 hours and i have not found any way to remove it. Any help is greatly appreciated.
use the short end to feel around the back side of the knob. You'll feel a hole on the back side. Press the allen wrench into the hole and push hard; the center section of the knob will pop out, revealing a Phillips screw. Remove the screw and the knob comes right off.
These instructions are for the vent window knobs...
Mike
Thanks a lot mike!
URL: http://www.GeronimosBones.com
If you look closely at the outer face of the knob you will see a tiny little dot in the plastic. This little dot is there to take the guess work out of feeling around for the hole on the backside.
