low current to coil
for some reason it seems the low voltage wires to the coil are only
generating 3-4 volts. the battery has a ok charge (around 11.5v) and
it's turning over ok. haven't found any loose wires or breaks.
needless to say the plugs aren't sparking (they are getting a mild
current though - ouch!)
anyone have a magic bullet?
+11.5v at the battery is _not_ ok. A fully charged battery,
regardless of kind, should be >+12.6V. At +11.5V (if that is the
accurate voltage reading) is almost fully discharged. That, coupled
with inherent resistance in the circuit, could explain your
problem.
How and under what exact conditions are you measuring the
voltage at the battery?
Chris B.
'73 ex-Malaga
