Sign in to follow this
what do i want to buy for drilling spot welds?
11 posts / 99 viewsLast Reply
im in new territory here and have no clue. i googled some stuff but its overwhelming. anyone have an idea of what i need? im not planning any serious bodywork. ill cut checks for that. i just need to remove some brackets from up in the nose to move stuff around and make some more room
It will cut all round the spot weld without having to go thru two layers of metal.
(nt)
Use an 1/8" cutoff wheel and go at just where the welds are...
I did a lot of welds with a hole cutter type bit, and some with a flat faced bit (mills away the metal). After Matt told me how he did it and trying out the technique, I knew it would have saved me shit loads of time for 99% of the spot welds I worked on.
Oh well. Don't make my mistake ;P.
(nt)
what's that Gem your pilioting ?
next beastie should be your 5 jamming up the apexes
URL: http://www.bmwquebec.ca/gallery/browseimages.php?c=47
It is a very technical track. We organaized a driver school a few weeks ago. The track has very tight hairpins, a tons of elevation changes and is a real gem to drive. Not fast as you keep in 2nd and third gear but it requires a lot of car control. We were preparin g novices for the bigger and faster Mont-Tremblant (aka BAB7) event in August. The car is my 1983 Hartge H23.
Better then any others I've tried. Or you can follow the same guys advice and grind them off.
URL: http://www.2002tii-restoration.org/
I've tried various spot weld cutters, but more and more I too use either a cut-off wheel or a drill bit. It depends on the situation and whether or not I'm trying to save both pieces of metal. Basically, I just do whatever seems most appropriate to make the metal thin enough on one side of weld to gently seperate the the two pieces with a chisel.
Cheers,
Martin
farting through silk, kid.
Wait'll you see whati've done now.
